1 - 20 of 21 Posts
I just completed the EZ EFI install in my 69 and I used a Ricks FI tank with the in-tank pump. Awesome tank. The tank is vented with a 3/8 line from the built in location supplied by Ricks and runs out to terminate by the gas cap.
The problem is the vent allows a lot of fuel smell to emit from the tank and really stinks up the garage. I've seen some guys on this forum solve this with installing a charcoal canister and I'd like details on the parts used and how to make this for my car. Where can I get parts that will work, be safe and can be installed nicely?
I appreciate your help!
Bob
Bob, I used a charcoal filter from a K car and installed it in the trunk. You most likely care about the appearance of yours a little more than I do though and could do it cleaner. You can search ebay for "charcoal canister" and maybe find one that'll work. The ones made for some motorcycles are small and easier to hide. I put a cheap plastic fuel filter on the outlet line to act like an air filter, not that it'll ever pull air in or that the charcoal can needs it. Typically, the outlet line would be run back to the air intake to consume the fumes while running but I'm lazy. I can sniff the end of mine and not smell anything.
You pretty much just have to find a charcoal canister that works for you and just get some hose and clamps. I couldn't really find a spot underneath the car where I felt like fuel would not slosh up the line into the can so that's why I put it in the trunk and put the vent in the filler neck.
The Help! aisle may have one you can plug on the end of the line that will do the trick. There is charcoal filter about the size of a pill bottle that is made to go on the brake booster line of older Corvettes to keep fumes out of the booster. I have one on my booster. It is part number 80195.
Bob, are you talking about the 1/4 pipe vent fitting on the forward side of the tank ( I have the 68 version in mine)? Can you post a picture of what you are talking about? What fuel lines are you running? Are they braided rubber or braided teflon? The braided rubber ones seep alot of fuel fumes, that why alot of people switch to the teflon lined ones.
Chris;
I don't have pictures, but yes it's the vent fitting on the upper side of the tank, forward on the drivers side. That has a 3/8 rubber fuel rated line running out to where the filler is (behind the license plate on a 69).
The fuel lines are steel braided nitrile lines from Summit.... so it shouldn't be those that smell (at least I don't think so)
Bob
Thanks Steiner...
I've got a canister I found that I think I can mount under the car and run lines to it and then out to the filler area. We'll see how it goes once I get it on the car...
Bob
Cool. If it gives you problems, here is what that Help! 80195 booster filter looks like and it has 3/8 nipples. I bet it'll go right on the end of the line at your filler neck. It's about the size of that fuel filter you see hanging down by my filler neck.
Why?
Just cap it and run a vented fuel cap.
Is it the line that is supposed to run up toward the cap and could be connected back into the filler line? When you are fueling up it allows air in the tank (displaced by fuel) to flow back toward the nozzle for quicker fill up.
Not sure if a 69 has one, but just an idea.
I would cap it.
Bob, on my ricks tank I have mine running over top of the differential with a inline plastic fuel filter attached to the end of the hose.
Did you have any problems with your ricks tank leaking from the supply side of the manifold flare?
Bill
Discussion Starter #9
Bill;
Not sure I'd call it a problem, but it leaked when I first pressurized the system with the pump on. I was able to tighten it up and get the leak stopped though. I expected a leak somewhere and that's where it happened.
Bob
Ya mine leaked to when I pressurized the system and I tried to tighten more and seamed like it stopped, but then I grounded the fast ez efi relay wire and let the pump run continuously and it still leaked only while the pump was running, called them and Hector said they were having problems with there new flaring tool, there sending me a new manifold
hopefully yours is not dripping while its running and causing your smell after you park it, mine dripped but not alot but enough to miss it if I was not looking for it untill it evaporated
Bill
Discussion Starter #11
I'll keep checking it to make sure it's not a problem after it runs a while.
Thanks for the heads up Bill
Bob
Bob
I have the same exact problem as you. I would love to know how the canister you bought worked out for you and where you mounted it. I've had old cars before but my garage has never smelled this strong before, so I hope this works out.
Discussion Starter #13
After eliminating all the fuel smell coming from the tank vent (the 80195 filter Steiner suggested got that accomplished), I still had the strong fuel smell. It wasn't from driving the car and it stunk up the garage anytime the door was closed. I finally determined it was coming from the braided steel fuel lines that Summit sells as nitrile lined - as Chris suggested previously. Turns out being OK for fuel doesn't mean they aren't vapor permeable. PTFE (Teflon) lines need to be used to eliminate fuel vapor emitting from the lines. So I've replaced all the Summit lines with Teflon and .... no more smell!
BTW: The Summit guys were awesome... after calling them about the problem, they gave me full credit for their braided lines, with shipping costs credited too.
Here's a thread on the subject.... live and learn!
http://www.pro-touring.com/forum/showthread.php?t=62575
Bob
Sweet. Did you have to get new fittings as well?
Bob
Glad to hear it worked out for you. Sounds like I will be doing the same, do you have the part numbers you used from Summit? I've got a spectra tank with no venting line just a venting cap so I hope the new fuel lines will do the trick.
Bill
Discussion Starter #16
Steiner:
Yup... I'm using Aeroquip teflon lines and their fittings for that type of line. Since they are a relatively thin teflon hose with braid over that, they are much thinner than the rubber hose with braid and require special fittings in steel (vs aluminum). The cost for the hose is about 30% more than rubber with braid. The fittings are about the same. Also, the crimping technique for the fittings is different than rubber / braided. You need to install a ferrule between the hose and the braid before inserting the nipple and threading on the base.
Bob
Discussion Starter #17 (Edited)
Thanks Bob
Yeah Bob, thanks. Summit is doing the same for me and I bought mine back in October. I'm just doing the line from the pump/filter to the regulator though.
1 - 20 of 21 Posts
