I'm not great with the electrical side of things so I'm asking for help in checking my work.. I'm trying to solve a fuel gauge problem (68, console) .
Problem--fuel gauge sits at full plus.
steps I've taken:
1. disconnected the line from the sender in the trunk and found:
a. when the line to the gauge is grounded the gauge reads empty--conclusion: guage and line to gauge are ok.
b. connecting an ohm meter to the sender line and find 20 K -- conclusion: sender ok since the tank is under half full and 45 K should be half.
c. make sure that the sender line and the gauge line are making a good connection--then connect them up--gauge sits at full plus.
Overall Conclusion: the ground to the sender is broken at some point?
Am I right to think this or have I missed anything? Is there any good way to deal with a broken ground without dropping the tank?
Many thanks in advance.
Sender is NOT ok. GM sending units are 0-90 ohms. You are getting a reading of 20k, which is 20,000 ohms. The reason why it is still at full plus.
I would look at the ground wire first, where it connects to the frame. Make sure it is clean, tight and connected to bare metal. Use a star washer too, it digs into metal to make a better connection.
The gagues are original (but maybe not to the car). Some of the wiring suggests that the console was added later.
Thanks.
