im owning an old 327 engine and i want to make it running 12s.13s on 1'4 mile
its a 327 69 camaro.
my idea is rebuilt it for sreet use.what combination do you reccomend....including transmission etc...
thanks
you can get to the times you want with the 327, but if you are planning to completely rebuild, you may want to look into either building a larger displacement engine. You could also consider buying an already built engine from one of these shops...
www.amerspeed.com www.allchevyengines.com www.sallee-chevrolet.com
Banned
As simple as just bolting on a set of 2.02"/1.60" valve double-hump heads and installing a Crane "Little Fireball" or CC 268HE cam, 1.625" four tube, long headers and an old Holley 1850, 600cfm or 3310-2, 750 carb. that is tuned to your engine! Also, the old -097 Duntov solid cam is a dandy here, too!! (I just had ta get it in this thread!!!)...
You can probably use a Weiand 8004 and a stock Q-Jet as long as it's tuned right for the cubes!
Clean the old double-hump heads up with some bowl work and casting flash removal and you are good to go! Just shoot for about a 9.75 to 1 CR. with the heads, deck height and shim headgaskets with the stock four valve notch flat-top pistons and again everything should be fine!
Now remember that the old double-hump heads won't last all that long on unleaded gas, but should do very well for you so that you can save your nickels and dimes for a set of modern heads that flow better.
As for your other post, the RPM cam is too big for a 327 but the heads should be fine if you want to spend the money.
I personally would opt for a set of W/P's 67cc S/R large valve heads unless you really want to go hard-core and get bigger/better flowing heads!
The guy I bought my car back from said he had a 12.9 second, So. Cal. strip, time slip, using a small set of slicks, with just such a combination and I will say the little 327 with the mild cam did run VERY well! It did however have an old stock cast-iron 300hp/327 AFB manifold and adapter for the 1850!! pdq67
