I need help, I'm having a problem trying to figure out if my gas guage is bad or my sending unit inside the tank.
I pulled the gas sending unit out of the tank and checked it with my multimeter, each time I moved the float up or down, it registered on the meter from about .80 down to 0 each full rotation.
Each time I turned the ignition to run position, the gas meter goes all the way to the right position, when I turn the ignition switch off, the gas gauge continues to stay to the far right position, doesn't move. I pulled the glass bubbles off so I could move the gas hand backwards to the emepty position while running my tests. Each time I turned the key on, the hand would rapidly go to the full right position.
Sinkit67 "Lets get started".
