1 - 15 of 15 Posts
I know this is a camaro forum but you guys have always been great when I had my camaros so.....Got a 65 fastback with a tank that is brand new(bought the car that way) The tank leaks gas when it is sitting in the garage at the sending unit. At first I thought it was the sending unit itself so just to be safe I replaced the whole sending unit gasket and hoses. Now the new one is leaking too. It is leaking at a rate of about a teaspoon and hour but it is very annoying not to mention dangerous. Some one told me the ethanol in the gas today will eat right through the rubber gasket around the sending unit so what should I do?
First off is it safe to drive the car to get it home?(20 minutes on the the highway straight shot home)? It only seems to leak when it is sitting still with the car off so I am assuming that the tank is pressurized enough to push it against the rubber and stop any leaks. Just want to get it home so I can drain it and get a better seal around it. Any ideas on a better way to seal it or a better gasket out there to use? The ring is as tight as it will go Thanks in advance!
Mark
TOOFUN
It should be fine.. One thing you can do is get a vented gas cap and that should help.
How does a tank leak gas if the sender is on the top of the tank? The tank would have to be 100% full to leak out the top, no? Kinda like a milk jug leaking out the top? It doesn't happen unless you turn the container over.
alan
Discussion Starter #9
alan
Yea your right on camaros but on Fords they put the unit in the front of the tank. I cant even begin to tell you why they do that but thats what they did. Probably because on the 65 the tank is mounted by dropping it in from the trunk with no straps. It makes getting it in and out real easy. Only problem is they use a tiny square cut oval ring to seal the sending unit. Real easy to pinch it and it is so tiny I cant see how it does a good job. Like I said it is a brand new tank so I dont have the benefit of 30 years of rust to seal it up(LOL) Anyways gonna pull the tank when I get home and see what I can come up with. Anyone know of a good gas sealant I can use along with the gasket it comes with?
Discussion Starter #11
Well I took the car home and wiped it down real good before I started it up. I drove home WITH A FIRE EXTINGUISHER from work just in case. So went to drain the tank and because it is a replacement tank....no drain plug. So I siphoned it out the old fashion way(mouth full of gas etc...) Took the tank out. Definately is leaking right from the sending unit itself right at the bottom. I carefully inspected the tank and there is No cracks around at all. Like I said brand new tank, ring, gasket and sending unit. So I pulled the sending unit out and inspected the ring. It is fine. Lubed it and put it back into place tighted the tang ring in place and if I put my hand on the outlet fitting I can twist the sending unit backa and forth. SOO AGGRAVATING!! The gasket ring they give you with the sending unit is so small. Almost feels like it has to be thicker or something. I even tried bending the holding tabs in a little so the ring will go tighter but it still will slide with a little effort twisting back and forth. SOMEONE has had to have the same problem. Do they make a thicker O ring type of gasket like the chevys have? This one is round but has a squarish cut to it.
I also heard about the vented caps but if I leave the tank with the gas cap off I still have the same problem. VERY FRUSTRATING to say the least. Is there any type of sealant that can be used to help this. Fuel leaks not only smell bad but are dangerous as you can imagine.. Thanks in advance.
Mark
TOOFUN
Mark
I have a 57 chevy with the same problem. The 57 also has the sending unit on the front side of the tank. After trying several things to stop the leaking, I did a Google search and found this product and no more leaking. VersaChem gasket sealant #2,leak-proof. The part # is 23009 and I got it at either Auto Zone or Oreilly's. Worked great for me.
Permatex #2 is good as well. It is fuel proof and non-hardening. Use some on both sides of the assembly, let it sit for a few minutes to get tacky, then assemble and leave it for a day before refilling.
It could be the tank flange(?) where the sending unit sits onto is not flat, or on the same plane.
Pull the sending unit out, chalk the gasket, then install the unit and remove the unit to see witness mark on unit for sealing.
Discussion Starter #15
Thanks everyone.. I am going to try the permatex #2 or versachem which ever one is at my local autozone.. I really think it could be a bad match between the sending unit and the repro tank but the drip is so small it is just enough to be annoying so I really think the sealant will work as long as it is rated to be gasoline tolerant. Although the guy with the 57 chevy used it and he has the same tank setup as my mustang so it should be good to go. MAN I LOVE THIS SITE! I always get the best info from team camaro and you all have proved me right again..even though I currently have a FORD! lol..
Mark
TOOFUN
1 - 15 of 15 Posts
