I've been reading a bunch of posts about the use and misuse of RTV and other sealants, but am still not quite sure what I should do in my case.
I'm replacing my current valve cover and oil pan gaskets and I got those nice Fel-Pro models. the oil pan gasket is nice blue one-piece metal reinforced rubber model, and the valve gaskets are a nice thick rubberish material, also reinforced i believe.
do i need any kind of sealer on these gaskets? i usually put some kind of sealer on every gasket I replace but i want these to be perfect, and after reading all those anti-rtv posts, i'm not quite sure what to do....
will be heading into the garage in about an hour, hopefully hear back from someone..
THANKS!
THANKS!
