Can anyone supply me with the GM part numbers for the relay and throttle arm switch for the cowl induction set up? Also looking for the number for a 23" small block fan shroud.
Thanks,
Gary
1969 Cortez Silver Z28
Fan Shroud:
69 Camaro 396 - 3947619
69 Camaro (8cyl)(exc 396) - 3938615
Those are the 2 numbers I found and descriptions in my GM parts book.
69 Camaro w/spec ducted hood:
3955225 - Frame assy - carb. air cont valve
7729602 - Relay assy
1114427 - solenoid assy - carb air cont.
3959115 - switch - carb air cont.valve sol.
3955226 - carb air cont.
3955227 - retainer - carb air cont. valve
3969803 - seal assy- carb air control valve frame
6484242 - sensor unit air cleaner thermal
Sorry, but this is what was listed and how it was listed in the parts book. I hope this helps some?
Discussion Starter · #3 ·
Thanks for the part numbers Jonesy. So what did the SB's use when A/C was installed? I have the 615 shroud and it's way too small.
Gary
