Ah, never thought of the disc brake angle...good point!
Just be careful, as someone commented here a while back that the teeth on the trim rings and caps will eat the power-coating off wheels and it is hard to "patch."
Orig 14x7 are SS wheels and will clear the disc brakes, only the 14x6s had drum versions. If they are actually YJ stamped, then you did good. YJ rallys are in the $50 to $100 each depending on date and if someone need to complete a set. Trim rims and caps are harder to value due to possible road rash and pitting on the center car. If they have either then they are not worth much money.
