read up on the products lol
http://kalecoauto.com/index.php?main_page=index
Modern synthetic oil is very expensive - so why run the risk of getting it dirty by running it through your motor block? KaleCoAuto bypass kit comes with everything you need to run the oil around your motor block where it will do more good. Oil runs cooler, and as a result, there may be horsepower gains!
Ahh the classic:You've heard of the Y pipe.. the X pipe.. the H pipe.. nothing can touch the O pipe!!! It provides 100% back pressure feedback on ALL engines!! Torque increase and kuneutson valve float brings in much lower revs so you don't hurt your motor! Not CARB Legal. Please specify standard or polished finish. Product shown is dual input O-Pipe with standard finish.
For you pro touring fans:Do you have an annoying rattling in your mufflers? Are they sagging a little? Don't quite sound right? That could be the symptoms of a worn muffler bearing. Allow me to introduce the KaleCoAuto muffler bearing! It's unique iron-graphite composite with pre-grease-packed assembly provides over 200,000 miles of smooth muffler operation! It is most likely they will outlast your mufflers. Also works well on heavy duty exhaust systems. One per muffler.
Good stuffWant improved braking? Why just cross drill those rotors? Introducing KaleCoAuto cross drilled brake lines! Improved airflow through lines provides superior brake cooling. Brake fluid is exposed to cool moving air, almost instantly reducing heat, and providing shorter stopping distances! All lines are made of quality latex. Brake lines come in: Red and Yellow. Please specify color when ordering!! Warning!! You must replace ALL brake lines at once. You may mix colors.
