Hi there
Car is running GREAT, with one issue (hoping it's not a major one).
Car starts right up - but after warming up, I hear a grinding/rattling noise (kind of like two ball-bearings that don't have sufficient lubrication, being spun around an empty can). The noise is constant after warmup. The car has proper levels of oil, coolant and power-steering fluid.
Here's a link to a video of the car running - you can hear the noise, especially when I get close to the AC unit (AC unit is new, but was added shortly before I bought the car).
https://www.dropbox.com/s/o05qbgfajd96cib/IMG_2799.MOV.mov
Any help would be much appreciated. Happy Friday!
Sounds pretty easy to diagnose. Take the belt off or use a long screwdriver up to your ear and place on components until you identify the problem.
x2- remove belts one at a time, see which one make the sound go away.
Also be sure to turn the AC clutch on and off while it's running. Could be too much slack in the clutch. (at least it isn't the compressor)
Thanks fellas! I'll try your suggestions. Any pro tips on removing and reinstalling belts?
