What is the Guildstrand mod? I'm want to go tubular front upper controll arms but have decided to get the car going and save it for this winter. When I do it should I do upper and lower, narrow or standard, with all the manufacturers which ones are good and which are junk? I have poly all around but how do greasable solids work or poly just fine? I have heard of the guildstand mod but what exactally is it?
Thanks,
Mike
I think you mean "gulstrand". Do a search, and you will find lots of info. You don't need both the mod and new A-arms. Do one or the other.
The Guldstrand 'mod' physically moves the upper control arm mounting location to a different location on the frame than that of the stock frame location. The movement in the location point is 0.900" downward and 0.250" rearward. this modification effectivly re-locates the front suspensions "Roll Center". (There have been many threads on the changes and effects of doing said modifications, you might want to do a search on this and prepare to sit back and read for an hour or so. There is a lot of info on this).
This mod will cost you noting but the time involved to preform the drilling of the holes and modification of upper control arm mounting plate (if you were to use stock control arms). You just need to download the template from Mr. Pozzi web page.
If you were to use Global West's control arms you will not have to preform any plate modification, just the re location of the holes if you want to do them. Doug Norrin (Pres of GW) states that it is un-necessary to preform the Guldstrand mod with his tublar control arms unless the car will be used for more agressive street driving, autocross or road racing. This doesnt mean that you shouldnt, the choice is up to you. With the GW arms you can do both the arms and the mod if you so wish. I myself would, but thats me. My 67 is aggressivly driven the entire time the engine is running......
The Detroit Speed Engineering control arms have their own 'location' modification. So if you were to use their control arms the Guldstrand mod would not be necessary, because they supply their own location points.
As far as changing the arm length, I wouldnt recommend that you change them.
So far the only "Real" choice is between the Global West and DSE products. Not too many others out there have products as good as GW or DSE. Global West sells upper and lower arms, where as DSE only sells the uppers at this time. They may in the future, but its not really necessary to change the lowers unless you run really big spring rates.....and I mean really big (like 1000 lb springs that you would use if at Talladega running 180+ MPH).
Bushings are or can be a critical choice. You need to ask yourself if you can live with a little more road noise and a very slight loss in ride quality (I have to laugh at that because the increase in handling totally offsets any loss in comfort to me). Both GW and DSE use solid bushings in their arms. You can get GW arms with poly installed if that is what you wish, but the soild bushings in the upper I think should be mandatory. The upper control arm controls the geometry and is not under the load like the lower control arm is and doesnt really effect ride quality.
If you wanted to play and tune the control arm geometry the DSE arms offer you the ability to change the caster bushings in the control arm. Not much there to play with, but you can pretty much do the same with the GW arms, it is just done differently. They both effectivly do pretty much the same thing, they are just two different companies with two different approaches.
