hi i have an 87 camaro gutted battery relocated ,90/10 struts,4" harwood cowl,[email protected] pro stick, 295/50/15 radial ta's summit seats, weld pro stars. about 3200#
355ci
dart platinum iron eagles 215cc 64cc combustion chambers 2.05 1.60 valves
comp magnum 294s soild cam 525/525 lift 248/248 @ .50
victor jr
holley 650 dp
headman longtubes 1 5/8
1.5 roller rockers
flat top speed pro pistons 4 valve releif
th 400 shift kit 3500 stall
3.73 gears
any h/p and 1/4 mile time guesses thanks
I have installed a similar engine (that I have yet to start) in my '69 Camaro except my solid cam is .480 lift but similar duration to yours. I have aluminum 64cc heads with 210cc chambers. I believe our CR with 4 relief flat tops comes in around 10:1, depending on deck height and head gasket thickness. My drag racer machinist thought it should be good for around 450 hp and that sounds about right to me. I went to 1-3/4" headers. I think they're worth a few ponies at this level. I will also run a 750 dp. Are you driving yours yet? How does it run? You and I need to quit guessin' and start racin'!!! :thumbsup:
