Thank you for welcoming me into a great Camaro forum.
I have a 1967 Camaro with what I assume a not standard tilt steering. I cannot get it apart. Pictured is as far as I can disassemble. Serious wobble. I think from the upper or lower bearing but I am stuck. Anyone offer advice is appreciated.
Automotive tire Wheel Motor vehicle Vehicle Steering part
Reactions: bnjgruber
Discussion Starter · #3 ·
Genius! I see it now. I will check when I get home. Thank you Jeremy. What are the size of your Vision wheels and backspacing if you don't mind?
No problem glad to help.
Front are 18x8.5 with 5.25 backspace 245/40r18. Rear are 18x9.5 with 5.75 backspace 275/40r18. My rear end is out of a nova so it is 1" wider. So 5.5 would probably work better.
