I have seen articles and cars using a nice polished upper radiator pipe hekd on by two short hoses with Gates power grip clamps. Can someone tell me where to get the pipe and short hoses? I have a 69 with a big block. Also being its a pipe with no ridge will the power grip clamp hold it secure without it popping off? Any help and pictures would be greatly appreciated.
can't help on the pipe, but just a tip... find someone with a bead roller - they should be able to add a retention bead to the pipe as long as the roller will fit inside.
From what I have heard and read, the power grip clamps should hold on without any beads necessary. I have not tried them myself, but they sure look a lot better than regular hose clamps :yes:
A certain former member here would have recommended raiding the drain pipe from under the kitchen sink. Really!
I don't know that you could find one long enough or big enough. The drain pipe from a sink is 1 1/2 dia, not sure what is required for a radiator.
Jeff
The first time you lean your arm against that metal radiator pipe you'll change it back to a rubber hose real quick. Those things get HOT!
