I asked a while back for suggestions for roller rockers around $200 and most suggested Harland Sharp. I am finally getting around to ordering them and notice that the max spring OD for the rockers is 1.450". This will work with my current springs but don't know if that is likely to cause problems down the road if I want to change to different springs.
Is it likely that this would limit me in the future or are most springs smaller than 1.450". I noticed that many of the others will accommodate larger spring OD's.
Matt
should work for you--u can still do slight massaging underneath to accomadate larger springs without hurting integrity but i havent had good luck w harland -the roller bearing dont last over 2 yrs for me but i run 660 open pressure
