I have a little problem, I need to know if there is any way to identify if I have a 327 or a 350 block. The casting number is 3970010. I guess this could be a 350 or a 327. I understand that you can tell the difference by measuring the stroke. 3.25 for 327 and 3.48 for 350. My question I guess is can I figure out the stroke without pulling heads back off? My second question is can I use a 350 balancer on a 327 or is this a seriours no no?
I found it odd that my balancer off my original 350 is on 6.75 inches diameter and thats when all the confusion started.
If you can remove your oil pan you should be able to find the part# cast on the crank, If it's a GM crank. I have a casting# book if you find the#. According to my book that block was used for 302's and 350's but someone could have put in a 327 or 307 crank or it could be stroked to a 383 or maybe something else.
Engine code from the front pass deck pad? You can use a 350 h/bal on a 327, but you can't use a 327 h/bal on a 350, not enough weight.
The thickness of the h/bal is determined by the stroke. More stroke, thicker rim on the h/bal. The factor is the amount weight of counterweights on the crankshafts. 283 & 307 have the same h/bal, thin, 3/4 inch width? 327 has 1 inch width? 350 has 1 1/16 inch wide.
Just some more info. The block when it was apart from what I can remember for sure had a 4 bolt mains. Just measured damper 6.75" by 1 and 3/16th. I just found this info on another website can anyone confirm that this is accurate.
Years Casting CID Main Caps Comments [SIZE=-1]
[/SIZE]
1968 3970010 327 - - 2 A
1969-79 3970010 350 185 370 2 or 4 car, truck, Vette
I am sure this is stupid question can you convert a 327 from a 2 to a 4 bolt main? I thought I had a 327, it is looking more like 350???
I am asking these questions because I really do not want pull anything apart again!!!!!
The damper is most certainly off 350 which sounds like it will work on 327 if that is what it is??
Yes, you can change from 327 to 350. Change crankshaft and pistons.
Yes, it can convert a 2-bolt to 4-bolt. As long as the webs are thick enough.
GM 4-bolt would be four parallel bolts per cap. Most aftermarket 4-bolt kits have the outer two bolts at an angle and maybe steel main bearing caps. If original GM 4-bolt, you could have a forged crankshaft as identified by a wide mold split line on the side of the rod journals, I think.
If you don't want to pull the pan, you can view through the oil drain plug.
