1 - 8 of 8 Posts
Can someone tell me the difference between a '67, '68, '69, and '70, 8" harmonic balancer for a 350 motor? Is there a difference in the way they are degreed? If you have a '70 balancer on a '67 motor, will the timing be right if you have a '70 timing chain cover? What about a '69 cover or a '67 cover with a '70 balancer?
Thanks,
Sean
I don't know about all small blocks for those years. But I do know that the 67-68 Z28 had a balancer with a different timing mark on them than the 69 Z28's did and they were not interchangeable.
The timing degree location was changed in 1969. I am going by memory, so it might not be 100% accurate ! I believe they changed by 8°. It is recommended that you do not mix timing covers and Harmonic balancers. If you "find" TDC on your No.1 cylinder with a piston stop, you can verify if your marks are correct for your timing tab.
Didn't GM increase the balancer diameter to 8" in '69?
Fred, I believe that more models of cars did get the larger balancer in '69. As noted there were some models that had the 8" earlier.
'69 was a pivotal year for Chevrolet with the Long water pump, different engine mounts, new accessory brackets with bolt holes in the ends of the heads etc.
Thanks men.
And we all know what happened because of the 'pivot'.:D
1 - 8 of 8 Posts
