I did think of that, They wont fit - the shroud wont fit on the new Radiator - the core is slightly larger than the new oneArkangel77, after going back to your post #12........how about trying your old Spal fans with the new shroud if they fit and seeing if there's any difference before laying down any more cash on another setup?
Your temp gauge has numbers correct?That was a FAIL - and I am lost as to what to do next? I jacked up the car - ran it and topped it off, then let it cool and topped it again before I drove it
It was 89 degrees outside during this test drive.
I drove hwy and back roads to the interstate. By the time I hit the Interstate it was @ 210.
I drove 6 miles on the interstate and it stayed at 210-212.
When I got off the interstate and drove home threw the City and on the Hwy it was around 215-220.
When I drove a little spirited the Temp Shot up 20 or so degrees and then slowly came back down.
Once I got home I let it Idle while in drive for a few moments to simulate traffic and it went up to 245 rather quickly.
I also checked the temp with fans running and key on vs engine running and there was a 30 degree difference.
Correct me if I am mistaken but it seems like Not only are these fans not close to keeping up butt this 1.25" tube Radiator is no better than the Northern I have with 1" tubes???
I am thinking of buying another temp gauge and compare it to the one in there now?
maybe something like this just to test it? Allstar Performance ALL80096 Allstar Performance Gauges | Summit Racing
But I think that's just wishful thinking at this point?
Yes SrYour temp gauge has numbers correct?
If you can safely get to a road where you can get up to say 45 mph and get home without it boiling over that might be interesting... but remove the shroud and fans intact if you do that. I've been tempted myself but before I do that I have to get out on the road. Maybe tomorrow if I can get the drivers seat installed.I did think of that, They wont fit - the shroud wont fit on the new Radiator - the core is slightly larger on the new one
I am tempted top take these CC fans off and drive it with NO fans just to seer what happens?
Where is your sending unit plugged in?Yes Sr
In the Intake - Next to the thermostat.Where is your sending unit plugged in?
How did you verify that?Yes Sr
Yes I think your limiting factor is the fans and shroud. Did you measure the current of those coldcase fans?@68rs76z28 - I had doubts about the gauge originally but I no longer do - It seems to be accurately representing the coolant temp. I have tested the set up a few different ways.
Thank you @slazisme for getting me to think about this again.
I did some tweaking today and got new results. I pulled the cold case fans/shroud off and trimmed my old dual 11" Spal fan Shroud from the previous radiator (2600 CFM setup). It took some gymnastics to get it in there but I have a solid 1/16" - 1/8" of clearance right now... I did my same trip, back roads to Interstate, into town and then drove home on a Hwy. Knocked around on some side streets before I got home (mimicking stop and go). It was only 88 degrees today. However on the way to the interstate the car went to just under 210 and stayed there. Stayed just under 210 on the interstate also. When I got in town and was driving around it actually got better? It was ranging between 203-208. I really don't know but I am assuming this indicated the fans / shroud is the limiting factor here? This result is similar to what the Old setup did. I am very curious what @dhutton Thinks?
I did not - I forgot my Amp Clamp. I can take it home and test them Just so we have that data. I will post those Numbers TomorrowYes I think your limiting factor is the fans and shroud. Did you measure the current of those coldcase fans?
Don
Can you tell us how you tested it?@68rs76z28 - I had doubts about the gauge originally but I no longer do - It seems to be accurately representing the coolant temp. I have tested the set up a few different ways.
9 amps. Those are toy fans.I did not - I forgot my Amp Clamp. I can take it home and test them Just so we have that data. I will post those Numbers Tomorrow
PS - Waiting to see how Willie makes out!
EDIT I figured I would just edit this post instead of making a new one. Just got done checking amps on ColdCase fans.
Inrush was 22 amps.
Running was 9 amps.
@dhutton
