1 - 2 of 2 Posts
Out of the 97 camaro GM service manual:
Tighten the cylinder head bolts to 50 N·m (37 lb ft) in sequence.
Use the Torque Angle Meter/wrench to rotate each cylinder head bolt 120 degrees in sequence.
Use the Torque Angle Meter/wrench to rotate the four center cylinder head bolts an additional 30 degrees in sequence.
Make sure you use new head bolts.
1 - 2 of 2 Posts
