1 - 2 of 2 Posts
I have the orrigonal double hump 2.02 heads for my DZ 302 that my uncle had machined about 25 years ago. I need to disassemble them and clean some of the sand out of them before I put them on the engine (distant future) and I need to store them. Should I pack them in plastic bags and oil, or should I use grease or WD-40? Thanks.
Joel
1969 Z28
LeMans Blue-White Stripes
#'s matching, P-O-P
Joel,
If it is going to be a while before you use them, and you are going to go through them anyway at that time, I would just spray some WD40 on them and sit them on the shelf. Plastic bags tend to make a lot of condensation when the temperature changes, I dont like using them. If the heads have been run, they are probably pretty oily anyway, they should be fine. if you can store them in a heated area of the house instead of an unheated garage, it is even better.
Hope this helps,
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
1971 Chevelle "Heavy Chevy" original owner
1973 Z-28 ..one family car...Brother bought it new in 73
1 - 2 of 2 Posts
