1 - 10 of 10 Posts
I installed brand new gaskets (Copper) with my headers,...the bolts are as tight as humanly possible, yet they are still leaking...
any suggestions on gaskets to use with Dart Iron Eagle heads?
I've used copper before, and usually spray it with Permatex Copper Coat (same as the VHT that Steve pointed out) or, I use Percy's Aluminum gaskets. They work like a champ. Make sure the header flange is flat though because that is the most likely culprit.
Get rid of the copper header gaskets. Get a set of Remflex gaskets and even if the flanges are a bit warped they will seal.
Just reading up on the remflex...I had never heard of them before--anyone else use them?
Discussion Starter #10
Just ordered a set of the remflex gaskets...I hope they work!
1 - 10 of 10 Posts
