Is there some sort of trick to removing the plastic plug from harness off the headlamp prongs?
I tried jamming things into that space in plug thinking there was a release in there.
I tried prying it off with various tools. If I apply any more pressure something will break for sure.
Take off the spring and remove the headlight from the bucket. Tehn it will be easier to get at the plug. It will pull off. No clips or release tabs.
Once you get it off you can grease the blades of the bulb with some Vaseline before plugging it back in so in the future it comes off easier. It will also keep the weather out of the plug.
You can also use bulb grease or dielectric
