They just push in and lock in place. There should be a spring loaded pin on the bottom of the switch itself that releases the locking piece that holds the shaft into the assembly. See if this pic gives you a perspective. If its not an RS model, you wont have the small hose bibs on your switch but the rest of it works the same. :)
