Hey all,
I was working under the dash of my '68 when i accidently pulled some wires out of the harness connector for the headlight switch. (someone had previously hacked the wiring and put in spade terminals that don't lock in...). Does anyone have the color/terminal arrangement for the wires going into the headlight switch connector? Maybe with a picture, or top to bottom and left to right or something? I'm looking at it from the harness side (wires going into the back of the connector). Thanks!
Looking at the back of a 68 ignition switch, starting at the 12 oclock position is the ACC terminal with a #12 Brown and a #24 brown/white stripe wire.
At about 1:30 is the Batt terminal with a #12 Red wire.
At about 4 oclock is the GRD terminal with a #20 dark Green wire.
Slightly inward towards the center at about 5 oclock is the KEY- terminal with a #20 black wire.
Right in the center of the switch is the KEY + terminal with a #20 Pink/black stripe wire.
At about the 8 oclock position is the IGN terminal with a #12 Pink wire.
At the 10 oclock position is the SOL terminal with a #12 Purple wire on it.
Marc,
Thanks for the reply. However, i was looking for the headlight switch. If you can be as detailed as you were for the ignition, i'll be in good shape!
Thanks!!
