I just replaced the engine harness that connects to the front lights, horn relay, voltage regulator etc.. and now the low beams dont work. Everything else works fine including the high beams. No blown fuses and all grounds seem to be ok. They worked yesterday!! Any suggestions? Thanks
Plain old 69 Camaro
check your dimmer button at your left foot area, wonder if you knocked the wires loose that plug into it, those cause alot of funny problems.
Jim,
I was just about to post that I found the problem when I read yours. It was the dimmer switch. I replaced it a few months ago and didn't expect it to be the problem. It was a loose connection. Go figure. Thanks
Mitch
