The male electrical connector on the heater motor broke off. Does anyone know how to fix it? First time had that happen, helper was bending it straight. . . . .
if you are talking about the connector on the wire, IIRC, if so easily replaced with crimp or solder types. If its the male tang that comes out of the motor...new motor
If any portion or the motor spade is showing, you might be able to solder on a pigtail and crimp a male spade onto the pigtail.
Strip the jumper about the width of spade, solder wire, lay wire against spade lengthwise, and solder wire to spade.
Good luck
