I am removing the heater box so i can install ac that i got from another car from the way it looks to me you have to remove the inner fender to get the outside bolts off is there any other way. thanks
You are going to have to remove the RH fender to gain access to all the fasteners on the evaporator box. I don't think you can get the inner-fender out(67-9)without removing the fender, and even if you could, access to the evaporator would still be very difficult. Somebody told me that the firewall for A/C cars has different cutouts than non-A/C cars. Hopefully you won't have to cut and splice sheetmetal. Don't forget the vacuum canister that mounts inside the LH fender by the firewall plug. This will be a real challenge to mount since you can't even see it when it's installed.
I recently went the other way from a/c to
just heat. The fire wall is defently different the opening for a/c is bigger also
the coil ends are in a different spot also there is some things like valves and stuff
inside the wells that are different
