yes, in fact they all have them. I imagine yours is burned out. They not easy to get to, either.
The light socket snaps into the pass side of the control unit, about an inch back from the front.
If you can't reach / find it from underneath, pull the glovebox out and it's right there.
And if it still isn’t illuminated enough, you can find a 68 Firebird control with the fiber optic cable that illuminates the left side of the panel using the same bulb. But if you do that then you have to change the faceplate background color from blue to black to match the Camaro style.
Discussion Starter · #4 ·
Thanks guys, I've replaced all the wiring with a kit from Painless. There was'nt a provision for this light. I looked through my cataloges for a suitable harness, but couldn't find anything that I thought was right. Guess I'll have to make one. Kevin
