1 - 2 of 2 Posts
hey guy, i am working on a 69 rs ss convertible, when i recieved the car the entire dash was ripped out. i have put it all back together but have one small problem. on the hvac switch, the middel lever goes to the center part of the ducting and operates a door the closes the heater and opens the ac vent. well that door is stuck. it will only move about 1/4 of an inch. the plactic ac door on the driver side hit the metal door on the pass side. how do i unstick the metal door so that it will close enough to get the door shut?
thanks for any input guys!
You mean the outlets door and temp door are bound up? One must have become out of position.Are you sure the 2 doors are binding together? I would remove the entire housing assembly and determine what's going on. It's rare for this to happen. I realize it's a lot of work just for this problem, but it also offers you the ability to seal the unit and replace the heater core (even if it's not leaking now, it will)at the same time.
1 - 2 of 2 Posts
