Do you know of any computer related problems where the car will flood
over for no appartent reason? I have replaced the coolant sensor on
the intake and the idle air charge and the Map.
P.S. I get a over charging code forgot to mention I also bought a new
alternator and i get a rich exhaust code forgot to mention I bought a
new oxygen sensor,I also get a mixture control code and yes I have
ran a check on the fuel pressure regulator and fuel injectors all I
know what is left is the ECM. Can any one HELP!??
Flood over?? Can you explain in better detail whats going on.Your replacing alot of parts there.All these codes happened all at the same time?
Have you checked to see what the actual charging system voltage is? If it is charging correctly, it may be a false code. In this case, you may have a faulty PCM, which could be causing your driveability problems.
Yes, and it's charging correctly and we put a brand new alternator on it just in case.And yes all the codes happened at the same time.
