i know this is a camaro site but i have a question. i have a 1993 chevy 4x4 and the silenoid went in it. i replaced it and that one went and i replaced it again and the silenoid gets warm with the engine turned off and the keys out of it. what do you do you guys think it could be? mabe something to do between there and the starter??
You probably should take the starter with you when you go to the parts store and have it checked out. There is always power to the solenoid so it is possible for a voltage leak in the starter. Try unhooking the small wires and see if it still gets warm. If so, you need to check for a huge voltage drain there. Right now though, I am betting on a bad starter.
Did you send me an email concerning a 97 Cobra? Someone did and I replied with several things to check but I received "delivery failed" notification. Whoever it was and if you still need it, I need a valid email address. The email I did receive was from a Bob R*****.
