well i bought the car and it is in need of some serious brakes probally needs drums all around "A" FRAME bushings and shocks. It also goes crazy after you reach a speed of 70 or so. The speedometer i think is 5mph to fast but i do know he changed the tires maybe they are to small i think the rear tires are 205 60r14's isnt that like a size too small?.
i was told if you pull the cable out from the speedometer (the insert part) and replace it not to lube it with like WD-40, only use vasoline or something is this true,
i dont know would you buy your drums at auto zone or try a junk yard for some that can be turned? maybe nows the time to goto disk in the front but wouldnt that take away from the original junk?. To many issues sorry
