Hey Guys,
I need some help. I own a 1984 Z28. Has a 305 engine. The previous owner got rid of the crossinjection & Comp. It now has a carb & a mechanical distribiuter. My car drives fine (when cold) but after 20 minutes it starts stalling and stops running. I changed the platina & condensor, spark plugs, replaced termostat, drained radiator and refilled the coolant. The water pump is O.K.
The fan is also O.K. I checked the oil...also o.k. The coolant hoses are new. But still it stops running when it gets hot.
help help help anyone....
no choke? heck theres the prob it runs fine when cold then when hot it stalls? the choke plate is probably shut or partly open,you need the choke operating for the carb to work?good-luck...
70camaroSS ground-up restification,350 slightly modified
Hey Guys,
Found the problem....tireblazin68 was right..
I changed the fuelpomp and the problem was gone...I put in a new 15psi carter pump with a nice presure regulater and I'm running like before again...I thank you all for your help...
