I just installed a new set of Hooker Super Competiton headers and a Flowmaster American Thunder Exhaust on my 68 SSRS 396. The headers have 2 inch primary tubes and 3 1/2 colectors. These new header hang down so low that I only have about 2 1/2 inches of ground clearance. If there is a pebble in road the headers scape. Has anybody else ran into this problem with the Hooker Super comps? Is there a different motor mount I can use to raise the motor for more clearence? What do you guys think?
Thanks in advance,
Nick
69 Z/28 X77 D80 83000 original miles,DZ 302, M-21, BU 373 Rear End, ZL-2 Ducted Hood, Daytona Yellow, Black Deluxe, Tilt, Factory AM/FM, Console Gauges.
get taller front tires and/or stiffer springs to bring it up a little bit. with stiffer springs, you can keep the same ride height and lessen suspension movement, thus less scraping. my nova has about 3" of clearnance from collector to ground, and they never hit. i have weak 6 cylinder springs that allow a lot of movement.
355sb, vortec heads, HOT cam,T-10 tranny, 3.70 gears 16" IROC wheels
