Discussion Starter · #2 ·
I think I just found the answer - I think it is a 2-series carrier. Doh! I just bought one on ebay without doing the homework first. I've got a set of 373 gears for it. I've heard that you can use a spacer. If so how much do they run and any problems with them? Seems like I read that you don't want to run them. BGH or anyone else your opinion please.
The 410409 is a 2 series 8.5 Traction Lock. It should have four large "9"s cast into it on the same end as the casting number. You can use a spacer, but I don't recommend it. They can cause some problems. Sometimes you can find a used 3 series case that has damaged gears in it. You can swap all of the internal parts from the 2 series into the 3 series case.
