Im installing the right stuff brake it and im stuck on the rear junction block.
Can somebody explain how to install the brake junction block to the rear axle?
If you have a pic that would be a great help!
I don't have a picture and I don't have a 67 AIM but I do have a 68 AIM. UPC 5 Sheet B5 has a picture. The bracket bolts to a drivers side upper diff cover bolt. Rubber line enters from front and line clip holds that in. Then a 3 way distribution block connects to the rubber line and 2 hard lines to wheel cylinders.
Best pic I could find online.
http://www.nastyz28.com/2gcog/rearaxle.html
Remember to mount the flex/rubber hose to the t-junction on the rear axle before you attach it to the front. Otherwise you risk twisting the hose which can make it collapse inside.
