In my friends chevelle, we want to hide the msd 6a box out of site. Our problem is now connecting the 6A box to the msd distributor. Does anyone have a part number for some sort of extension harness? There has to be something for people who mount the 2 items farther than 6" from each other? I searched but turned up nothing. Thanks
Nope. I extended mine using the same gauge wire, solder, shrink sleeving and mounted the box inside on the upper portion of the pass toe board next to the firewall seam. drilled a 1.25" diameter hole, put a grommet in it and ran the harness through it.
I just added wire and put it in beside my battery in the fenderwell...can't even see it...
MSD part 8860 this cable is 6ft. long about $12.00 hope this helps :thumbsup:
yeah, I was gonna say mine is so long it's almost a nuisance but I didn't have the p/n. til now. Thanks Doug.
and so I went and found it on their website, it's under accessories/harnesses
Wolf....They also sell replacement 2 pin connector assemblies so you can cut your existing cable to the desired length.
David F.
