Okay it part of the driver window switch harness. Its a wire connecter that crimps on and connects the wire to the pin of the window switch. Been searchin all night and i just cant figure it out. one of Mine has broken on my 98 camaro and i need the quick fix. Thank you so much !
Post a picture or take it off and take it down to your local parts store.
1998 Chevrolet Camaro, 3.8L V6, auto, window switch connector, drvr's door.
www.rockauto.com, AC Delco P/N PT187
Having the name of Sue, probably would make a better man..........Susan would be better.
You guys are hilarious, lol. Anyway. the above picture is correct, all im looking for is the metal attatchment where the wire connects to the rest of it.
I was thinking sadie. And no that is not short for Mercedez.
Discussion Starter #9
Sorry for the slow response guys. There is like six wires coming out of the door, into the black piece. If you take the back side off of the pictured wiring harness, you will see how the wires connect to the pins. It is a bit that crimps to the end of the wire, and has a 90 degree angle allowing the pin connection to the wire. One of my pin connecters is broken.
Sorry for the delayed responses and the lack of specificity.
