1 - 11 of 11 Posts
1968 camaro... i just installed my engine and tranny...small block m21 trans. the clutch fork hits the firewall!!!!!
i have all stock stuff.
diaphram type press plate,
the correct fork i think. are they any different ones?
small block clutch linkage.
do 1968 camaros use the long throwout bearing? mine has the short one.....this all came with the clutch kit
If you can't find a GM fork, you could also probably remedy it by using an adjustable pivot ball in the bellhousing. They're $16 from Summit / JEGS
Wagonman...
Is the engine and transmission in place on the mounts without being jacked up? I remember doing a changeover for a friend and the fork hit, I let the transmission and motor down and it was fine. Its not to say you have the wrong fork or pivit ball....as others have suggested.
Kev
wrong T/O bearing.........went thru this last year, There is a tall and short one and sounds like you have the short one.
Just reread your post. So you do have short, this takes to much of a throw to engage pressure plate allowing the fork to hit.....the taller one takes much less movement to engage the PP and therefore doesn't allow the fork to hit the firewall. I learned the hard way also but my I can have trans out in an hour now!!
Would the short T/O brg cause the trans to not go into gear all together? My clutch fork does also hit the body but I can't even get he darn thing into gear with the engine running. The trans was purchased as "known good"; beyond that I don't have much other info. Do you think the T/O brg is the culprit or should I also suspect interna trans issues? Thanks for your help.
Trans NO-GO
Would the short T/O brg cause the trans to not go into gear all together? My clutch fork does also hit the body but I can't even get he darn thing into gear with the engine running. The trans was purchased as "known good"; beyond that I don't have much other info. Do you think the T/O brg is the culprit or should I also suspect internal trans issues? Thanks for your help. :confused:
The correct clutch fork is still avaible from GM do a search on my name & it will show a post in this section that has all the current part #'s for the clutch fork & some other needed parts. they are a lot cheaper than going thru a Camaro supply store. Johnny
Re: Trans NO-GO
Did you install a new clutch or when did your problem start?
1 - 11 of 11 Posts
