Help removing rear seat
878 Views 2 Replies 2 Participants Last post by  thorpe67RS
I am trying to remove the rear seat in my 67. Can someone tell me how to get it out. Its a fold down rear seat if that makes any difference. I cant see any bolts and dont know if it justs pops out but dont wanna yank on it without knowing. Thanks.
The bottom is removed just like any other camaro rear seat. The top is removed by loosing up the two nut on the bottom corners of the seat hinge. You then lift up the seat and there is a slot in hinge that will let the nut go through. Then it should just lift out. Good luck Jerry
