1 - 2 of 2 Posts
Can someone direct me to forum or other free help to diagnose..........
92 NISSAN P.U. 4 cyl that overheated for 1st time ever.
Fan Belt is in place.
Waterpump is turning.
How do you diagonose water pump and T-stat operation ???????
IF you would please Email me at [email protected] I would greatly appreciate your opinion........
Thanks, Chuck
Thermostats are cheap and easy to replace, so I would go ahead and replace it anyway. While you're there, the waterpump isn't hard to replace either. I used to drive an 87 Pathfinder, and they are very similar other than the Pathfinder was a 6cyl, so I had less space to work. You can troubleshoot the t-stat while installed just by checking the upper radiator hose while it's running. If the hose doesn't get hot, then the water isn't flowing like it should at normal operating temperature. If you pull the t-stat you can check in in a pot of boiling water on your stove, but at that point you might as well replace it since they only cost a few dollars. Hope this helps.
-Rick
1 - 2 of 2 Posts
