1 - 15 of 15 Posts
All,
I'm scrambling to locate a special bolt for a '69 vert.
It's the bolt that holds the convertable top cylinders in place. The end of the bolt is smooth (like a carrige bolt, except reversed) and is threaded about half way up the stem.
Unfortunatly none of the usual supects ie...Rick's, Classic Ind, NPD carry these pieces of hardware.
Anyone know of a specialty hareware maker that might have these?
thanks,
grey899
I bought a front end bolt kit from AMK products. Everything was in separate bags, and labled nicely. You can find them at AMKPRODUCTS.COM. I may have a catalog at home, and check it tonight if you want.
I'll check tonight when I get home. I have a 69 conv parts car.
Rick Dorion
69 RS Conv,355,M20,4.10's and I don't worry about stone chips ( yet ).
Is it something like this?
If it is, it's called a shoulder screw and Mc Master Carr sells this and a whole bunch of different types. Search their site www.mcmastercarr.com
Our affair with Camaros is a live sentence without the possibility of parole. www.geocities.com/c68ss http://home.coqui.net/borench
[This message has been edited by ORENCH (edited 08-06-2002).]
Discussion Starter · #5 ·
Rick- Appreciate any help, thanks.
ORENCH- just reverse the thread and smooth area, and thats what the bolt looks like...I'll check with your references, thanks.
67killerb- thanks, I'll give them a try
grey899
Gray - a carrage bolt has a button or smooth head and a square section right under the head that locks into a square hole so you don't need a wrench on the bolt head. What you want if I understand you correctly is one of 2 hex head bolts that don't have threads on the end of them. Call Steve or Scott at Steve's Camaros 650 873-1890 and see what he has. Tell him you need fasteners for a power convertible top ram and he'll know exactly what you want.
...Dennis
"The '69, the '96 & the club"
[This message has been edited by DjD (edited 08-06-2002).]
Discussion Starter · #7 ·
All,
I found a place in Calif that re-produces and makes everything for convertables, specialty bolts included...:)
They do come at a cost though...$15 bucks a bolt, and they only sell them in pairs..ouch
Oh well, if you need it, you need it.
Their # 800 333-1140
thanks for all your help
grey899
Grey,
I have a suggestion for you since you own a ragtop.
Instead of replacing the bolt w/orig style and its nut, why not replace the upper bolt with a clevis pin and hitch pin, similar to the towing hitch pin on the receiver.
This way, come winter time, one can disconnect the cylinder yoke from the frame and sink the cylinder rod into the cylinder for safekeeping to prevent rusting of the shaft and tearing up the seal next spring when the season opens?
I did this to another brand of conv I had and it worked great. You can get them from McMaster-Carr and thet accept c/cards and ship to your door. They even have them in Stainless Steel.
Everett,
Your suggestion is a good one but the bolt(s) in question are the ones that hold the ram in place, there is no nut on them...
The ram I replaced a few weeks back had a rod that was quite pitted. If you store a ragtop it might indeed help to disconnect the rods from the top and lower the rods into the rams...
...Dennis
Hey Dennis, please stop torturing me. Every time I see your car with the new set of wheels, I can't get to sleep trying to find a way to afford a set of those for my 68. No kidding, that car looks awesome.
1 - 15 of 15 Posts
