I got my wiring all hooked up finally and I have a problem that I haven't seen before. When I hit the brake pedal the dash lights come on. it's like when you pull the light switch out half way and the valence lights and tail lights come on. The brake lights do work though. What's the problem?
Thanks, Dan
Sounds like a grounding problem. Are all your ground wires hooked up under the dash? What about in the trunk?
I had some similar problems and I traced them down to flaky ground connections.
Good hunting!
-Marc
all my grounds are hooked but I will clean them up and give them better bare metal. thanks
I checked all my grounds but it is still doing it.
