Hi all,
Have joined on here and posted couple threads, regarding the following.
I have engine that I was about to rebuild, checked out the engine block, head and crank numbers.
Engine block # 3892657
Head # 3890462 A37 Jan 1967
from what I can make out it is a RPO L48 Factory 295 Hp 350 which was only used in 1967 SS350 Camaros
The block has been bored before and heads a rebore to 0.040th also has what seems to be original intake manifold, before I go ahead and do anything, to this is it worth any real money and by that I mean more than its going to cost me to replace the engine block, heads and crank.
Hi hp fan welcome to TC... Got a real name? You'll find the folks here very helpful and that you only need to post a question once. Check the "Whats it worth" forum when you have time I put your question there since you are looking for the value of your block.
