Welcome to Team Camaro!
You should be asking this in the Electrical section.
You should do a search of the archives there too, there is a lot of good info there.
I put a wiring diagram on my page. http://ourworld.compuserve.com/homepages/David_Pozzi/67rswire.jpg
David
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
65 Lola T-70 Chev 350 Can-Am Vintage Racer
[This message has been edited by davidpozzi (edited 06-19-2001).]
I had a similar problem - found a ground loose - connected it tight - now they work every time.....
Mine was the ground behind the limit switch on the radiator support.
Steve
I had that problem. Check the stop switches (limiting switches) on the doors. Make sure they trigger the switch. Then try swapping the relays around in different positions. If they close but not open after swapping, then you have a bad relay.
