Just got new mini starter from Doug Herbert performance. The gear is to close to the fly wheel. It came with directions on how to fix, but my wife cleaned the garage and threw away the paper work. I have the parts to fix, just wondering if anyone may know how to fix before I open up a new starter in the dark.
you add shims between the block and the starter until you get the correct clearence. if the starter did not come with shims you can get them at any auto parts stores.
Discussion Starter · #4 ·
Its not the shims between the block and starter I need the gear is actually against the flywheel. The starter came with a 1/16 in spacer. I have already install the spacer inbetween the aluminum block of the starter and the starter body. Everything seems to work ok.
