Did the first gens have any towing package?
Has anyone ever put a hitch on one?
If not and you fab one onto a camaro, how much could you tow with it.
Im thinking like a small trailer for motorcyle or jetski?
Tony
obnoxious 67 camaro under construction. TH350/383 stroker w/ aluminum Edlebroc RPM heads,cam, and carb. Guldstrand mod, Hotchkis 600lbs springs. Next Hotchkis swaybar and disc brakes.This is a "Daily Driver" that still needs A LOT of work.
I have seen a hitch before on a Camaro. It was "U" shaped with the tops of the U bolted to the bumper. There was an added support bolted somewhere under the car.
Gawd...someone welded a hitch on my car. Welded it to the tail pan in fact. I guess I'm lucky that the tail pan had rust and needed replacing anyway. Going to have to get a cutting torch to get the rest. Are you sure you want to put a hitch on a camaro?
-dnult
i cringe everytime i see a car being pulled behind an rv.. can't be good for the poor transmission. if a car needs to be pulled, get a trailer.
355sb, vortec heads, HOT cam,T-10 tranny, 3.70 gears 16X8" IROC wheels. 12" Corvette brakes on the way.
see pics here http://community.webshots.com/user/novaderrik
[This message has been edited by novaderrik (edited 07-14-2002).]
