Holley 850 annular booster.
81 air bleeds and came with 37 idle feed restrictors, mixture screws out 1 1/8, idle is 13.5-14, lean cruise is 12.5, wot is 12.8. So I went with 34 IFR, mixture screws are now out 1 3/4, idle 14, lean cruise the same? WTH?
Lowered the floats, nc, any body have any other idea how to get the lean cruise above at least 13.5?
Banned
What cam? Specs? New carb? Rebuilt? Holley gets them pretty darn close out of the factory as they flow test each carb.
Timing made a good change for me when I was playing with my AFR gauge.
My IFR's are at 1/2-3/4 turn out
Closed the secondary's at idle (1/4 turn off seat so not fullyclosed/seated)
Played with my timing
All together added up to 13.8-14.5 @ idle once warm
Vacuum went up almost 2 points
Mid-High 12's @ WOT
Cruise is 14-15 depending on speed.
Mighty Demon 750 DP
73/85
6.5 PV
38 HSAB
