1 - 8 of 8 Posts
Some guys that are tunning there carbs will use this as a feel for a better AFR. Bigger air bleeds will help out to a point lean out your AFR and vrs..
Someone plugged the two air bleeds in front of the airhorn where the air cleaner sits. I thought these should be open? My carbs a 396 Holley 585cfm.
I'm guessing this is Todd (?)...
Those aren't the bleeds. There are two adjustable air bleed screws located there. The actual bleed passage can be seen inside the choke tower--they're the outer set of holes. The air bleed screws intersect the bleed passage and were used at the factory to fine-tune the idle air/fuel mixture for the lowest emissions. The carbs which had these screws from the factory did not use a conventional pressed in "restrictor" bleed on the idle air circuit on the primary side (inside the choke tower) as most other Holleys do. They are well-known to be a potential source of problems, and many rebuilders/restorers disable them and convert the idle circuits to a fixed calibration by installing air bleed restrictors as found on conventional Holleys.
Hopefully that clears that up.
Eric, the 4053 DZ carbs do not have them, right? Sure seems like they are a good thing to have. Do they offset the idle feed restrictors?
Gary;
Actually, the DZ carbs do have the adjustable air bleed screws. Many GM Holleys from `66 to `70 have them. I convert every one that comes in to fixed calibration and I've not had a problem with it yet, as opposed to when I left them alone--I had a number of come-backs with complaints of getting the idle mixture to take a set. Those screws are very susceptible to vibrating out of adjustment, and naturally many novice tuners spot a previously undiscovered screw and just have to give them a turn...
Disabling them and converting to fixed idle calibration (as with "conventional" carbs) simply eliminates the variable.
1 - 8 of 8 Posts
