1 - 10 of 10 Posts
Installed my CTS tonight and am not happy with the clearance between the harness and the header. As I see it I have a couple of options:
1) Insulate the wiring with a wrap, etc
2) find a shorter adapter fitting
3) find a CTS that is 1/2" NPT instead of 3/8 NPT.
Anyone have a good solution or recommendation on a sensor or "shorter fitting"
Do you have a spot available up on top by your thermostat? I didn’t so I used a 3/8” brass tee to put two sensors in the one spot by my thermostat.
Hopefully that will get you the needed clearance. What intake manifold do you have? Most aftermarkets will be tapped with a 3/8" fitting on top of the water cross over. When I installed my EFI, I used the top fitting for the CTS and the one you are using for the stock sensor.
It's an RPM air-gap. I had heard people saying the intake ports might not be good enough for the CTS. I guess I can try it in the rear port of the intake.
I also have an RPM Air Gap. My temps in the back of the manifold were 15-20 degrees cooler because the coolant was just coming from the radiator. Like I said before, I used a 3/8” NPT street tee to put two sensors in the front, right before the coolant goes back into the radiator. Something like this, but you can probably find something cheaper: https://www.oreillyauto.com/detail/b/american-grease-stick-2775/hardware---fasteners-16585/brass-fittings-16690/pipe-thread-fittings-18437/42cdacce856a/american-grease-stick-street-tee/ptf74b/6108740?q=3/8+street+tee&pos=1
Discussion Starter #9
Well, for now I decided to run it in the front of the manifold. Once I get things dialed in I'll try moving it to the rear and see what happens.
1 - 10 of 10 Posts
